do I just need the cameras? Do they connect independently to my existing wifi?
  • 1 Reply
  • 2119 Views
Painintheass
I want to buy arlo pro 2 cameras. I have ATT wireless wifi. do I just need the cameras? Do they connect independently to my existing wifi? Do I need a base station? I am unable to find that information seacrhing the net?
Streak2
Master Master
You will need to use the supplied base that comes with any of the Pro 2 kits.
You connect the base via ethernet to your ATT gateway and then the cameras set up their own wirless network back to the base.
https://www.arlo.com/en-us/products/arlo-pro-2/default.aspx
Streak2
Master Master
  • 1 Reply
  • 2120 Views
