add pro2 hub
the arlo app does not have an add device option. Neither does the website. I have a pro2 hub I purchased years ago and I'd like to add it now, how can I do that?
It certainly does.
Let us know if you see "Library" in the app at the bottom, or if you see "Feed" and "Dashboard" instead. Once we know that, we can help you find "add device".
@StephenB I see Library between Devices and Mode. Running Android, app version 4.10.2_2861 released 11/08/2023 if that helps.
Thanks! I did find it and after a little putzing, was able to add the hub.
