  • 1 Reply
  • 1240 Views
  • 2 Likes
Doombar
My question before I buy is:
Would the cutting of the fiber to the premises compromise the whole system.?
Most uk houses have a wire that enters the house at the front and is mostly unprotected. So if cut I’m thinking the whole system is useless. Is this correct?
AncientGeek
Hero
Hero
Not entirely.
Since the Arlo Pro, the base stations have been equipped with a USB storage option which will allow local recording even when the network circuit is down.  However, you can only view these recordings by removing the USB drive and attaching it to your computer.  The Arlo Q Plus also has a micro SD card slot for this purpose.
Of course, all camera systems are inaccessible remotely if the network is down, so no matter what you installed, you would lose remote visibility unless you had a router that offered both a wired and a cellular uplink capability.  There are a few of these available.  You can use fiber optic or cable as the primary link and if that fails, the router can switch over to the LTE circuit.
AncientGeek
Hero
Hero
Not entirely.
  • 1 Reply
  • 1241 Views
  • 2 Likes
