I have seven cameras and one is not functioning correctly. It is on a covered front porch. The running man is black, the battery is charged. I am able to see a live view and take a snap shot. It stopped recording motion 5 days ago. I powered down the base/router and put it back on. It is armed. I did a motion detection test and no red light flashed. Any suggestions would be appreciated before I go overboard with the troubleshooting. These cameras were purchased this year. Thanks!
Thank you very much, James. Will give it a try.
MelBO,
Consider removing the camera, resync and test motion again. This can be done by logging in to your Arlo account and navigating to Settings > My Devices > select the desired camera > Remove Device. After it's been removed, resync the camera with your base station and test again using the default "Armed" mode to see if you still experience the same behavior.
I did as you suggested and it worked! Thank you again for the very kind assistance.
Can you re sync without moving the camera? ie- when you are in a different country than your camera...
backyards Aspirant, I don't see how that is possible when you need to manually press the sync button on the base and on the camera. I took my camera down and brought it into the house. You may want to contact Arlo support. Perhaps they can do it remotely from their end for you.
