When trying to access my library (settings) is registered "0" --no longer recording motion. Did I accidently change something in settings. Would like to capture motion activity as did in the beginning
I'm confused by your post. Settings and library are two different things. It sounds like you're saying the display in the Devicees tab for a camera shows 0 recordings. That counter is reset when you visit the library to view them. If you use the library tab directly, can you see your recordings? If not, is a filter set (see if the funnel icon at the top is filled or empty - if filled, click on it, reset and save)?
If that's not it, tell us in detail what you're trying to do and what you see.
