will the camera fit on the magnetic mount with the power adapter ? Sorry for the dumb questions but want to check before drilling holes and climbing the ladder.
You shouldn't have a problem to have your Arlo camera fit on the magnetic mount with the power adapter plugged in. What I would suggest is to test it out first before you screw your magnetic mounts on to make sure.
Hey Nanlee,
Which magnetic mounts are you referring to? Is it the wall mount or the table/ceiling mount?
it is the one that came with the camera, the magnet.
