Will the  camera fit on the magnetic  mount with the power adapter?
  • 1363 Views
Nanlee
Luminary
Luminary
will the  camera fit on the magnetic  mount with the power adapter ? Sorry for the dumb questions but want to check before drilling holes and climbing the ladder.
JessicaP
You shouldn't have a problem to have your Arlo camera fit on the magnetic mount with the power adapter plugged in. What I would suggest is to test it out first before you screw your magnetic mounts on to make sure.
JessicaP
Hey Nanlee,
Which magnetic mounts are you referring to? Is it the wall mount or the table/ceiling mount?
Nanlee
Luminary
Luminary
it is the one that came with the camera, the magnet.
JessicaP
  • 1364 Views
