Will it be possible not to get notification sent to me when animals are running?
I am about to buy an outdoor camera system and am now looking into the Arlo pro 2. My question: I have a lot of animals running in my backyard. Will it be possible to not getting alarm triggered and notifications sent to me when cats and deers are running in the backyard?
It can be possible, but may not be easy....
I've found with small animals ( cat ) usu the camera's sense needs to be higher ( and camera mounted lower for good response )... deer are another story because of size.
The best info I can recommend is to only cover areas close to the house where people could be ; cause the PIR devices only detect people out to 25 ft ... also you will have to lower the sense level to still pick up people...this will require lowering the sense at a low rate of 1-2% each time with testing in between.... You should be able to find a sweet spot which eliminates most of the false triggers
Thanks!
Would I get more possibilities with Premier plan where I get the feature "Person, Vehicle, & Animal Detection"?
S
Yes then you can turn animals or whatever you don't want off and not get a notification for that category but will still record to library with that label. Its not perfect but works most of the time for me. Like TomMack said deer are hit or miss. I have alot.
Thanks for answering. Now I have bought it and will try to figure out what works and what does not work.
