  • 1812 Views
Letterman445
Hi,
I have a number of Pro 2 cameras, without a paid cloud subscription.
I’m wondering if I’ll get any notifications if a camera or the hub loose connectivity, particularly if the cameras are armed or in a different mode set to record on motion?
Thanks for clarifying.
@Letterman445 wrote:
I’m wondering if I’ll get any notifications if a camera or the hub lose connectivity
Unfortunately not.  There's also no logs available that will tell you this.
The only way you'd know is if you see an off-line status when you use the app or web interface.
Letterman445
Thanks Stephen.
Are there “device offline” notifications with a paid cloud subscription then?
Unfortunately, no.
  • 1813 Views
