Why cameras stop recording every 1 or 2 month, they need a hard reset to record again.
  • 614 Views
Rodaaa
Cameras stop working every 1-2 months, i need to unplig them, remove battery and then they work again
ShayneS
@Rodaaa
Does this occur on all the cameras at the same time?
Rodaaa
Yes, all cameras stop working, not really sure if it happen exactly at same time.
How can i do hard reset on the cammeras without having to remove the battery?
what camera models do you have?
There is no way to do a hard reset with the Pro or Pro 2.  All you can do is remove/reinsert the battery.  That just reboots the camera, it doesn't actually reset the camera.
  • 615 Views
