Which Outdoor Mount Works For Arlo Pro 2?
  • 2 Replies
  • 1360 Views
  • 2 Likes
cch0
Can anyone recommend which outdoor mount works better for Arlo Pro 2?  The product page doesn't mention if it works for Pro 2. It only says it supports Pro.
  • Outdoor Mount in White (VMA4000)
  • Outdoor Mount in Black (VMA4000B)
  • Outdoor Security Mount in White (VMA1000)
  • Outdoor Security Mount in Black (VMA1000B)
Any limitation with each kind?
Thank you!!
All Pro cameras are the same relative to mounting.
Dave32B
If you plan to plug it in, some of the mounts interfere with the mini usb connection. I had to modify one mount with snippers to allow the usb to plug in.
  • 2 Replies
  • 1361 Views
  • 2 Likes
