What is the best wifi router to use with the Arlo plus 2 system?I have a Neteger C6300 and it seems like the system is slow. I use xfinity internet.
It's really router-independent. What are your download and upload speeds as measured by speedtest.net?
Like @jguerdat says, take your pick.
To help narrow down your choice, forget about the Arlo kit, think about the other things that you want to do with your local network.
You currently have a C6300 cable modem. I'd look into the "seems like the system is slow" thing before spending any money.
If you can explain what it means over in the Netgear Community for that kit you might be able to fix it.
Cable Modems & Routers - NETGEAR Communities
But you'll have to say a bit more than "seems slow".
Remember, you won't get a router to speed up your Internet link. That is down to xfinity. But you may be able to make local stuff play ball.
Just another user
