What is the best way to turn cameras off when monitoring isn't needed. Unplug the base station?
PS
As and added info... you can d turn off the camera in settings under the device ( device on/off ) but the savings in power over disarmed is so small that it's just easier to disarm.
The main reason for turning off camera in settings is a privacy mode that only the primary account holder can turn it back on. ( shared users can not )
For longer time such as storage, remove batteries from all cameras and unplug the base station.
@Dannybear wrote:
Easiest way is to set the mode to “Disarmed”.
Just want to add that simply unplugging the base (while leaving the cameras powered) is a bad idea.
The cameras will start actively looking for the base, and that will result in the camera batteries being drained fairly quickly.
PS
