What Are The Indicator lights?
  • 1 Reply
  • 1874 Views
Dagostinelli
I have 2 arlo Pro 2 cameras, niether has any indicator lights on, ever.  Is this a problem? How do I fix it?
I must sya I am happy with the quality of the cameras but support is nonexistant and very frustrating. Am ready to return them
Streak2
Master Master
As you attach the charger the light should flash blue briefly and then go out.
If set to on on in the settings, then the light will turn blue once fully charged.
Remove and refit the battery you will get a blue flash.
Other than that there is not usually much activity from the lights during normal operation.
https://kb.arlo.com/642/What-do-the-different-LED-behaviors-on-my-Arlo-Wire-Free-or-Arlo-Pro-Wire-Fr...
  • 1 Reply
  • 1875 Views
