  • 5 Replies
  • 2189 Views
zhromanik92
Took my camera down from the mount to be charged. Full charge and remounted it. Now it is showing the weakest signal strength (red) and not able to record video. Prior to charging, the camera was working properly with full signal strength. Location of the camera has not changed, base station location has not changed, software is up to date and nothing has changed with the wifi. Camera is only 4 months old.
5 REPLIES 5
ShayneS
Hi @zhromanik92
Have you tried to remove the camera from Settings > My Devices > Re-Add it and test again?
zhromanik92
Yes I did. Still no change after
ShayneS
@zhromanik92
  Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech Support
Arlo_Chupar
Customer "service."  I've called them several times.  English is not their first language.  They don't understand.  If the issue isn't listed in their standard script you are SOL.  I'm stuck with a poor system.  What a waste of $$$
ShayneS
@Arlo_Chupar
Can you provide a little more detail regarding the issues you are experiencing?
  • 5 Replies
  • 2190 Views
