Viewing Arlo on an IP Client Multi View
  • 6 Replies
  • 7549 Views
Paulmidi
I have an IP Cam Client where I can group together several camera feeds but I don't know how to add my Arlo Pro 2 cameras to it.
It says
Camera Model
MJ or H264 ?
Camera Name
Host
Http Port
Media Port
user name
password
                             How do I find what all of these entries should be? Please explain in easy steps?
Thanks for any help!
6 REPLIES 6
Not going to work.....
the camera aren't ip cameras and they talk only to the base ( which has no access like normal wifi routers )
Paulmidi
Okay I hope I can ask about a different camera since the Arlo won't work.  What about a Logitech
Circle 2 camera how can I connect that?
Dannybear
@Paulmidi
Are you asking if the Logitech can be added into the Arlo system?
What are you trying to achieve in using the ip client software?
I previously had my arlo camera’s live streaming to my TV on command using google mini and a Chromecast dongle on a hdmi tv.
Much simpler using the Arlo App on iPhone and iPad.
Paulmidi
I would like to be able to view all of my cameras on one screen but they are all from different families I have a circle 2 from Logitech I have a Foscam I even have a couple of cell phone cameras with the at Home App. There has to be a way to incorporate all of them into one big view, doesn’t there?
I can see my Arlo system will probably not be a part of that system since it has its own base station as the other poster pointed out
Dannybear
I am new to all this as well but the arlo camera wifi is closed so you should get better protection from unwanted wifi attacks or so I think.
Someone else here may have some suggestions on how you could inter grate your cameras.
Be aware that arlo is trying to add apple home support, although progress has stalled while they sort out their existing bugs. Not sure of what functionality will be available when they do though.
Paulmidi
I believe I read somewhere the Arlo Baby Camera is the only Arlo that is accessible to the Apple Home App at this time.
My Logitech Circle 2 camera paired up with the Apple Home app in no time.
  • 6 Replies
  • 7549 Views
