Videos not in library for two of my four Arlo Pro 2 cameras
  • 1011 Views
LAFox
I've had 4 Arlo Pro 2 cameras for ~1 year now.  Today I noticed that for 2 of the cameras no videos are stored on server for past 7 days. There are plenty of videos for the other 2 cameras. Batteries are fine (at least 50%) for all 4 cameras. The server (at my.arlo.com and on the app on my iPhone Xr) initially stated there were 200+ videos and has the blue dots under the date indicating there are new videos, but despite that the libraries are empty ("no recordings") for those 2 cameras.
Prior posts on this community indicate server issues prevented storage of the videos, but I doubt that is the case for only 2 of the 4 cameras. No recent posts on this topic that I found.
Any thoughts?   Thanks  in advance.
LF
I just want to point out a recent change in behavior on this.  Before the blue dot meant there is a recording for the specific camera for that date.
Today the blue dot is displayed if there is a recording for any camera in the account for that date.  It's not clear if that is a bug or an intentional change in behavior.
Can you live stream these cameras and make manual recordings?
LAFox
Thanks for the info re: the blue dots. I was unaware.
One of the cameras overlooks the driveway and should in the least have us pulling in and out of the driveway in our vehicles. Those videos are not there.
I can live stream the 2 cameras that do not have any recordings.  And I can make manual recordings.
The first thing to try is to reboot the two cameras by removing the batteries and reinserting them.  If that doesn't restore normal operation, I suggest removing them from the account and resyncing.  If that fails, then contact support: https://www.arlo.com/en-us/support/contact.aspx
You can also connect a USB thumb drive to the base, and then check if the recordings for these cameras are being saved on the thumb drive (but not being stored in the cloud).
  • 1012 Views
