VMS4230P cameras Will NOT connect to the base. Tried removing devices but can't connect.
  • 1 Reply
  • 773 Views
Hans_madsen
hello i bought an Arlo Pro 2 wire-free HD security camera. I had it installed but came to press remove device so one camera disappeared. now i can't get it to connect again. I then tried to remove the other camera too and now none of them want to connect. I`ve Trier to restock it all, but it Will not work
If you are adding it back with the mobile app, then I suggest trying https://my.arlo.com in a PC web browser.
Also try removing/reinserting the battery on the camera(s) before resyncing them.
  • 1 Reply
  • 774 Views
