Hi All,
I'm planning on adding a couple more cameras to my Arlo Pro 2 system. Just wanted to know if there are any differences between the add on camera models VMC4030 vsVMC4030P?
These additional camera's will be used outdoors...
Thanks 🙂
Yes there is. The 4030 is the Arlo Pro and the 4030P is the Pro2.
https://www.arlo.com/en-us/products/arlo-pro/add-on-camera.aspx
https://www.arlo.com/en-us/products/arlo-pro-2/add-on-camera.aspx
Thanks Streak!
Just got a little confused with some sellers advertising the VMC4030P as the "2018 model". I thought there might have been some kind of hardware update.
Thanks again 🙂
