VMB4000 Base Station is offline. Internet light blinks intermittently. Tried resetting.
  • 1 Reply
  • 1038 Views
ras1020
MY BASE STATION READS THAT IT IS OFFLINE. I HAVE TESET IT . DISCONNECTED  IT. BYPASSED THE LINKSYS AND BROUGHT BASE STATION DOWN TO WHERE THE MODEM IS. THEN I GOT A GREEN LIGHT FOR INTERNET AND THEN IT WOULD START BLINKING INTERMITTENTLY.
Lower case also, please - easier to read.
Since you get the Internet LED working when connected to the modem directly, it's something about the router that's causing the issue. Many times just rebooting the router helps. Other times a setting in the router is causing the lack of connection.
  • 1 Reply
  • 1039 Views
