VMB4000 Base Station /Pro2 models mixing newer ones with older.
  • 2 Replies
  • 1137 Views
daleslad
I have two Pro2 cameras combined with a VMB4000 Base Station and I'd like to add two more later model cameras.
I want to know if I can mix newer models on the same base station.  I'd also like to know which of the newer cameras have  a better reach for detecting movement than the Pro2 cameras  that only reach  a meagre  12-15 feet
dcfox1
Yes the newer cams are compatible with the 4000. Just remember you need a subscription for cloud recordings on them.  Can't say if detection would be better in the position you have the pro2 mounted as that makes a difference. I had a Pro2 and detected farther then 15 feet you stated. This link list compatible cams
What is the difference between each Arlo SmartHub and base station?
dcfox1
daleslad
Thanks for the info.  and the link.
  • 2 Replies
  • 1138 Views
