Good morning I have VMB3000 serial 48E46970A1607 hardware VMB3010r2 firmware 1.12.2.8_556_dd3c705 that suddenly doesn't answer. The three led (Power, Internet and Camera) are green and fixed. No USB attached. If I disconnect ethernet cable, the Internet LED remains fixed and green. If I push SYNC nothing happens. I have to press ON/OFF button and then the base station restarts. Work correctly for 2-3 days and "freeze" in this mode. This happens after last firmware update. Before
it never happened. Can I rollback to previous firmware version?
No but it might be worthwhile to bite the bullet and reset the system. Remove all devices from Settings, My Devices. Hold the reset button untill the LEDs flash amber. Let the base reboot to green power and Internet LEDs and start fresh. It's a pain but should clear out any weirdness caused by firmware. Be sure to note all settings and any modes and rules you have set to speed the rebuild.
Of course, it's possible that he base is dying...
