It may be.... the non arlo ac adapter may not put out enough power for the camera....
Also, it will never charge the battery as the Pro/Pro2 need a qualcom type dual voltage ac adapter ( 5v and 9v to charge )
If plugged into AC, you have a choice to leave the battery in or not ( no difference except if a slight power failure, the battery keeps the camera runnig )
As to why it goes off-line, there can be many reasons... if it is just one camera, then swap it with another to see if it is the location ( interference ) or the camera ( problem follows camera )
I have been just using an aftermarket OEM USB plug for the mains. Not sure if that is factor but when I am connected it seems just fine.
