Use Echo 21 to display all Arlo cameras
Anyone have any luck using the new Echo 21 as a constant monitor for Arlo Cameras? I tried a fire TV with Tinycam Pro and had no success. I want to setup in Kitchen so there is a constant feed to the Echo from all the Arlo Cams. Thanks for any suggestions!
Just to clarify - you cannot stream the cameras 24x7. The streams will time out after 20 minutes or so.
