Usb local storage keeps disconnecting
  • 15 Replies
  • 5207 Views
  • 6 In Conversation
lendelbogdan
Usb 3  256GB worked fine for 4 years now keeps disconnecting after 1min.
I formated everything again using the Arlo Hub. Worked for 5 days. Now same problem.
15 REPLIES 15
ShayneS
HI @lendelbogdan
Are you still experiencing this issue with your local storage?
lendelbogdan
Yes. Still a problem
ShayneS
Is it possible to test with a different SD card?
turkeysub426
I have the same problem.  Sometimes it disconnects fairly quickly (after a few minutes).  Other times it takes a few days.  Very frustrating and defeats the purpose of having these cameras.
ShayneS
@turkeysub426
May I ask which troubleshooting steps you have performed so far? I don't want to suggest anything you have previously performed.
lendelbogdan
I restsrted hub.
Formatted usb using hub.
Tried USB on PC to make sure it's working and can write and copy. (Works fine).
I made sure there is over 16gb space.
ShayneS
@lendelbogdan
Is there any chance you can test with another SD card?
lendelbogdan
It's not SD. It's USB.
I tried another one and it's working for now.
But other USB worked for 4 years without problems. Now keeps disconnecting
turkeysub426
Previously, I had just restarted the base and the USB would reconnect.  But like I mentioned, it would just disconnect again (after just a few minutes in some cases).  This time I decided to reformat the entire drive and try again.  It's been running for 2 and a half days now.  I'll post any updates I have whether it disconnects again or not.
Details of my system:
Base:  VMB4540r2 w/ 1.21.0.0_1377_a58d08a firmware
4 cameras (H10 w/ 1.060.12.2_6_fd2b14a firmware)
Doorbell (1.2 w/ 1.18.0.0_1478_6e6deea_6853d06 firmware)
mblakebiellier
I think there are firmware issues.   I have two Arlo Base stations with the same issue.
One of them started saying there is an issue with the USB at the beginning of May.  I purchased a new USB drive.   It worked for a few days and the same thing happened again.
This week the second hub started having the exact same issue.
There is a problem with the firmware and this needs to be resolved by the Arlo Dev team ASAP!
Thank you!
Goddag10
Any update to this feed?
lendelbogdan
No solution. No update.
Arlo needs to fix the issue
Goddag10
Almost like they're trying to force us on to a subscription
turkeysub426
Update:  After formatting, my USB drive has stayed connected for 5 days now (since 5/12/2023 @ ~1pm EDT).  Let's see how long before it disconnects.  Hopefully, it won't...
drdoom
I am using VBM4000r3 for about 6 years already. My current firmware version is 1.21.0.1_4291_7841d8d. My arlo app in my iPhone Xs Max is also the most updated version.
I have been using a 400GB hard drive before for local storage. However in about 3 months before, the arlo app suddenly shows that the hard drive cannot be used for storage and requires formatting (which the app does not allow me to format).
I therefore tried to shift to use a 32GB USB storage stick for local storage. I have also formatted using FAT32 in computer before inserting into the arlo station. However, normally after 2 - 3 days, the arlo app would show that the storage stick is corrupted and requires formatting. The app does not allow me to format but I need to remove the stick from the station, format it using a computer and re-insert into the station. Then after 2-3 days, the problem happens again and keeps looping again and again.
Does anybody know how to solve this problem? Can any arlo technicians help?
  • 15 Replies
  • 5208 Views
  • 6 In Conversation
