  • 2071 Views
  • 3 Likes
SSpain81
Very frustrated with Arlo Pro 2....ready to return... Spent almost $400 on this camera (Arlo Pro 2) and I am unable to connect on my phone with the cameras.  I tried connecting on my PC and I am unable to log in.  First it tells me that I was logged out and to log in.....no go.  Then it tells me to allow Flash player, which I did and it still does not log me in.  What good is a camera when you cannot connect to them at all.  I have tried the troubleshooting suggestions, but I'm still unable.  One of my cameras is using all of its battery quickly and the other is still charged.  Too many issues with these cameras.
Is there anything else to try before I take it all down and return the darn thing?
Using Kaspersky antivirus? Seach here for solutions - Kaspersky is blocking access.
FOr Flash, click on the "click here" link in the banner and select Allow to run Flash. Current browsers are disabling Flash by default.
Bansheefan
Maybe try resetting the Base Station?  It almost seems easier to operate this on a mobile platform in my view.  You could also try deleting and reinstalling the app or re-linking the cameras to hub.  I am always able to see live cameras either at home or over cellular connections so keep trying!
Dannybear
If still no joy, contact support as your base station may require a firmware update to work.
  • 2072 Views
  • 3 Likes
