  • 4 Replies
  • 986 Views
PNelson
I have had multiple USB flash drive failures in the Arlo Pro2 VMB4000r3 base station.
The drive goes into read only mode to protect the existing data.  I can read from the drive, but no longer write to the drive.
I reported on this back in 2021.
https://community.arlo.com/t5/Arlo-Pro-2/Two-Sandisk-Cruzer-USB-Flash-Drives-going-bad-within-6-mont...
I upgraded to a SanDisk Ultra 32 GB and it lasted almost 3 years.   I probably have gone through 3-4 USB flash drives.  SanDisk has replaced them under warranty.
Has anyone else experienced this problem?
Paul
PNelson
I noticed my more updated post from 2022.
https://community.arlo.com/t5/Arlo-Pro-2/Recommended-USB-stick-for-base-station-VMB4000r3/m-p/187820...
I have gone through 4 USB drives.  The Ultra model lasted longer (almost 3 years) than the cheaper (?) Cruiser model that lasted less than a year.
Paul
When you connect the drive to a PC, does Windows offer to "repair" the drive?  If so, let it do that.  Then try to write a file to the drive from the PC.
Often the read-only mode happens when the drive is pulled without ejecting it from the app.  Or sometimes when there is a power failure at the hub when the drive is in use.  There is a "dirty bit" on the drive that flags that problem.  The windows "repair" will clear that bit.
PNelson
I attempted a Windows repair but there was a message saying ( i think) the drive is write protected.
I noticed the problem with the USB Flash drive after I rebooted the base station.  Perhaps the reboot caused the problem?
I am careful to use the eject procedure to remove USB drives from computers, etc.
Paul
The info here might be useful:
If you rebooted by power-cycling, that is a possibility.  If you rebooted using the app, then the base station should have finished any writes that were in process before it rebooted.
  • 4 Replies
  • 987 Views
