  • 1 Reply
  • 2865 Views
PNelson
I have had two Sandisk Cruzer USB flash drives, 32 GB, that are plugged into the base station go bad within the last 6 months.  If the flash drive detects a problem it write protects itself to prevent loss of data existing.   Therefore, I can read existing data from the drive.
Has anyone else had this problem?  Are there more reliable flash drives?  Could the Arlo base station be causing a problem?
Paul
I've just stuck any old thumb drive in with no issues. This sounds like something you should take up with Sandisk.
  • 1 Reply
  • 2866 Views
