Hi,
My Arlo Pro 2 shows US time when it should show Finland time. How do I change the 12h display in 24 hours?
Not sure about 24 hour clock settings.
Check the base station time zone is set correctly. If not change it back and power cycle the base station to make sure it sticks.
Then monitor regularly as it will likely change again while arlo sorts out firmware bugs.
Hope this helps.
Hope this helps.
Could this be relevant?
Solved: Re: Arlo Pro 2 every night changes time zone - Page 18 - Arlo Communities
By the way, embedded pictures will not show up in messages until a moderator has approved them. This is not tried of pictures added as attachments.
Just another user
