When thumb drive is full the app says it should overwrite old recordings, this doesn't happen. It just stops recording. I have to reformat to enable recording.
3GB is a problem. New firmware requires 16GB.
Hi @mgarnham
May I ask which troubleshooting steps you have performed so far? I don't want to suggest any prior methods you have previously performed.
Version R2 S/N 5TN1987EA0059.
I have only tried reformating the USB and restarting the Base Station.
Forgot to say the USB Drive is 3GB.
Have changed the USB thumbdrive to 16GB so will see what happens. Thanks
Dear fellow users,
Anyone has this issue? App keeps crushing when I open. Now I can only set my Armed time on schedule and not Geofencing. Worst is I cannot check my cameras while I am away from a computer. This is getting very problematic and surely Arlo has a fix on this. Totally no access on my iPhone now.
Have you complained to Apple yet? Every time an OS vendor makes a change risks breaking apps. It's not just one side - it's both.
