Thread size needed on the Arlo Pro 2 solar panel
Can anyone tell me the thread size of the solar panel bolt where it attaches to the wall mount? We are looking at getting an extension arm. The 7" Wall Tree Articulating Magic Arm has a 1/4" and 3/8" th inch thread. We just want to know if these are compatible. thank you
All of the threaded holes/bolts on the arlo gear are standard photo equipment of 1/4-20 thread.
Length of the thread isn't as critical as many use a locking nut.
