The previous activity zones disappear.
You may notice your unable to get notifications or recordings from your cameras that are configured to use activity zones.
The Activity zones have been removed and trying to access the activity menu of the camera is impossible as it continually spins the wait icon.
You will need to reset the problem pro2 Camera using the pull battery for ten seconds method then reinstall the wanted activity zones again.
Message 1 of 1
68
0 REPLIES 0
