Is there a mount available, that will screw on to the pro 2 (not magnetic) and not interfere with the AC plug that enters the camera. Every one I've tried has a tightening wheel that won't work due to the extremely close proximity of the rubberized AC plug. Thank you very much
The VMA4000 ( black or white just screws in without a lock wheel )
The 1000 model as mention above is taller, it was changed in that the older ones had a larger lock wheel, the new models the wheel is half the size ( due to your problem )
BTW, you can always use a small 1/4-20 nut on the mount ( smaller than lock wheel )
Yes. This is the one that I use with my AC cord.
1000 mount old style lock wheel
1000 mount new style lock wheel
This mount combines a ball mount with a pedastal and swivel. It also includes a cord and headless screw that screws into the threaded socket to slow down a thief. The headless screw doesn't interfere with the magnetic mount. I got these on Amazon.ca, likely should be available in the Amazon for your country.
Thank you very much! That would suffice.
Thank you, Eric 182! You and TomMac solved my issue. I appreciate your photo very much!
Thank you very much, TomMac! You and Eric 182 solved my issue. I appreciate your detailed answers! Jimmaaaay
Thank you very much, TomMac!!! Problem solved!!!
Thank you very much, Eric 182 Jimmaaaay
