Static noise in recordings Arlo Pro 2 cameras
I have 3 wireless cameras on my house and suddenly they all have a static/hissing noise in the background of the recordings. What is causing this and how can I stop it?
You can try removing all devices from Settings, My Devices and start fresh to see if that helps. If not, use the Contact Support link at the bottom here.
Thank you, I'll try that.
I removed the devices and now I can’t add the devices back because it says no devices found. I unplugged the power cord and Ethernet cable and reinstalled the Arlo app several times but it still can’t find the devices. What else can I try?
Hi Lghpublish,
Did you perhaps also remove your Base Station as well or did you just remove your cameras?
Are you viewing this through the Arlo app on your phone device or the web client on your browser? Is it happening on both?
I only know how to view it through the Arlo phone app. If there’s another way please let me know.
Browse to my.arlo.com in your PC browser.
