  • 8 Replies
  • 1860 Views
Lghpublish
I have 3 wireless cameras on my house and suddenly they all have a static/hissing noise in the background of the recordings. What is causing this and how can I stop it?
8 REPLIES 8
You can try removing all devices from Settings, My Devices and start fresh to see if that helps. If not, use the Contact Support link at the bottom here.
Lghpublish
Thank you, I'll try that.
Lghpublish
I removed the devices and now I can’t add the devices back because it says no devices found. I unplugged the power cord and Ethernet cable and reinstalled the Arlo app several times but it still can’t find the devices. What else can I try?
JessicaP
Hi Lghpublish,
Did you perhaps also remove your Base Station as well or did you just remove your cameras?
Lghpublish
Hello, I figured out that the administrator had to deleted me as a “friend” and reinvite me and grant access again and then I was able to add the cameras. I still hear a lot of static and background noise.
JessicaP
Are you viewing this through the Arlo app on your phone device or the web client on your browser? Is it happening on both?
Lghpublish
I only know how to view it through the Arlo phone app. If there’s another way please let me know.
Browse to my.arlo.com in your PC browser.
  • 8 Replies
  • 1861 Views
