The sound is very choppy. I cannot understand what's being said. Any suggestions?
5 REPLIES 5
What's the signal strength from the camera to the base? What are your upload/download speeds?
The strength shows weak. I have ATT. Suposed to be the fastest. The cameras are just a room away.
Every one of them say signal strength weak?? Gueuss it's my wifi
Your WiFi has nothing to do with Arlo. The base creates its own WiFi cobbection to the cameras. The house construction as well as camera and base positioning relative to each other can make all the difference in the world.
Oh. Thank you. I will work on that. I need to read up i guess. Thanks again.😃
