  • 4 Replies
  • 2707 Views
persychung
A charging fault been detected.
My solar panel works prefectly before.
But one day it cannot charge anymore...
I've tried unplug, re-connect, restart base station...
WHat I can do?
Best regards,
Persy
Gildor1
That's a tough one.  If you have a multimeter maybe check to see what kind of output the panel is producing in sun and dark.  Hopefully there is a spec somewhere someone can share on what it should be.
It seems that a number of cases has to do with the cable not being fully seated on each end, letting water in. I had the issue myself not long ago and it appeared that the panel was bad. After letting it sit inside for a week or two, it worked fine! Plugged it back in outside and it worked for a while and then failed. Swapped cables with another panel and it's perfect. The cable seal was the problem in my case.
It could be the same thing for you but first you have to determine that's the case. Let things dry out until it works properly. Ensure that both ends of the cable are well and truly seated - it can be a real PITA. The snaps on the panel need to be fully seated. The camera end needs to be wiggled to ensure it can't be inserted more (I've found that it seems the camera connection seems to be the more problematic connection).  If it happens again, I'd submit that the cable seal has an issue so you should contact support here for a replacement.
Had a similar issue... pull cable out and then used a product called cable seal after checking and re-inserting
Cable seal is a tape form like putty that never hardens but allows good seals on outside connections.  been using it for alot of my radio transmitter cables for years.
Nice thing as mentioned, it can be remove later unlike silicon caulk... but still seals well, no issues since
https://www.amazon.com/Universal-Electronics-Original-104-Moldable/dp/B0002ZPINC
persychung
Thanks for all you guys' suggestion.
I'll try and test.
  • 4 Replies
  • 2707 Views
