Solar panel was working great then after temperature and a little snow it now has a charging fault(triangle with a lightning bolt) and is draining my battery not charging it. Couldn’t find any answers to this problem. Have plugged and unplugged and all the suggestions but to no avail. I am familiar with solar panels and it’s pretty straight forward technology. What have you guys done , as I think there is a voltage drop through the cord. The cord is the problem in my mind.
Already answered in thread below.
https://community.arlo.com/t5/Arlo-Pro-2/Does-Arlo-Pro-2-have-some-kind-of-temperature-sensitivity/t...
@Trapperhayes The issue is with the battery not the panel. You cannot charge lithium ion batteries below ~32F. Solar panels actually work a bit better when they are cold though.
