How do I set a mode so that the siren will sound on the base station if either camera 1 or 2 is triggered.? It only seems to let me set the siren for 1 camera and not both. Thanks
Message 1 of 4
2,009
Siren activation is an option per camera rule. Edit the rules for the cameras in the recording mode you use and your should be able to toggle the siren on/off in each rule
Message 2 of 4
1,999
Message 2 of 4
1,999
Thanks, I've just got the system and I dont know how to edit the rules for the cameras in recording mode. Is there a step by step guide anywhere? I only want to set the siren to come on if either camera is activated when not in the property. Thought I could do this by setting up a new mode but you can't set up amide for both cameras?
Message 3 of 4
1,992
Sorted it, thanks for the advice
