Siren option is missing where cannot turn on when motion is detected on Arlo Pro
There is no way to turn on the siren when motion is detected by the arlo pro cameras.
Edit the Mode you're running. Edit the Rule for the camera you want to trigger the siren. Click "Add Device". Select the Alarm, which is the name of your base but with the red siren icon. Set how long you want the siren to run for and how loud it should be. Click Save
