Setting zone schedules Arlo Pro 2
Hi. I want to set up rules for 2 zones on one camera which is using AC power. For example, I want the zone 1 to record the lawn and sidewalk at night. I want zone 2 to only record the lawn during the day when there is a lot of activity on the sidewalk. Is there a way to do this with both zones on a single camera?
And can I set up different alerts for each zone?
You may be able to create a custom mode and select only the desired zone for the camera and then create a second custom mode with the other zone selected. I don't have any powered cameras right now to test but this used to be able to be done. You can then use the schedule to switch between the two. Notifications would be set in each mode.
Thank you. I will try this. The other problem is that I can't see my camera in mode. Only the base is showing.
Click on your base to see your modes and to be able to create your own custom modes.
