Sent invite but when logged in but they cannot see devices
I just set up all the devices. Everything was successful. Want to add a friend. They created account and I sent invite to that email address. When they log in they see no devices. On my account it still says their request is pending. There is nothing for my friend to accept. Am I missing something?
Hi atom5583,
Did they click on the invite link when they received the email?
yes. they created an account and then couldn't see anything i had set up already. It was just like it was a brand new account.
Try removing their grant access and re-add again to see if that works.
Hi Ralegna,
Make sure that you choose the cameras through the grant access page that you want to share with your husband.
I am having the same problem Have gone thru correctly all the steps on mobile devices and computers and the invitation stays as pending. I believe something is not working with the arlo software
Hi phr1,
Did they click on the invite link when they received it through email? And make sure that you choose the cameras through the grant access page that you want to share.
*IMPORTANT— If you have an Arlo System at two different residences, unless you want to pay a subscription fee, both you as the administrator, and your added “friends,” have to use a different email address for each residence/system. I hope this works for you. If not, you could call Arlo for help. We had to call them a while back for something on our primary home system and they were quite helpful. 🙂
Same problem as well. New setup is working, followed all instructions to add wife, gets invite, logs in and cannot see camera, base station. Looks like asking for new setup. Tried numerous times. Any assistance appreciated.
I would suggest to contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Purchased Arlo Esstential Kit today from Best Buy. Same issues as other report. I created an administrator account for myself works just fine. Tried creating an account for wife through grant access. Select all cameras send invitation. She accepts invitation created an account logs in and NOT able to see devices. Please advise.
Thank you.
Have the friend create a “new account” with their own email address and password (either online or by downloading the app) then send them the invite to join your account, once they click the link in the email (after creating their own “new account”) they will be asked to sign back in using their own information and then they should see the option to add existing devices. If not, make sure the friend is using the same WiFi network that the device(s) are on in which they’re trying to add (note: if prompted during setup, allow permission for the device to locate other devices on the home data network).
Hope this helps someone else!
