Selling My Arlo Pro 2. How To Reset?
HI all,
I am going to sell my 3 camera Arlo Pro2 system.
What do I need to do to reset everything, base station, so the new owner can set it up ok?
Thank you.
All you need to do is to remove all devices, starting with the cameras and finishing with the base, from Settings, My Devices. If you want, also hold the reset button for >10 seconds, until the LEDs flash amber.
Not sure what this has to do with this thread but we need all details to help. Did you claim the base first? Are the batteries charged? WHat base and cameras are you trying to use?
Ya gotta answer ALL the questions. And there may be more based on your answers. My first thought is a dead battery but you have to provide ALL details.
Sounds like a faulty camera. Swap at the store or use the Contact Support link at the bottom here.
Hi, for a set of second hand Arlo Pro 2s and the basestation, does 'hold the reset button for >10 seconds, until the LEDs flash amber' also removes the base station and cameras from everyone else's accounts?
@GearsofNet wrote:Hi, for a set of second hand Arlo Pro 2s and the basestation, does 'hold the reset button for >10 seconds, until the LEDs flash amber' also removes the base station and cameras from everyone else's accounts?
The base station must be removed from previous owners account by them since it linked to them. I believe then you can add the cam to the base after that since it is linked to the base. Not sure where you got them second hand but hopefully the seller will cooperate if the last owner.
