Seen the cameras only record one at a time
  • 2 Replies
  • 737 Views
Raheel
Seen the cameras only record one at a time so if one’s recording and there was some motion on second camera it wouldn’t record.
I'm not sure what you're trying to say but if you have sufficient upload speed through your ISP (with the Pro 2 I'd suggest 5Mbps minimum) multiple cameras can record at once. Of course, that means your modes and rules are set to do this.
I suggest testing this by aiming two cameras (placed side by side) at the same area, and then moving into it.
As @jguerdat suggests, you would need at least 2 mbps of internet upload bandwidth (preferably more).  The signal quality between the cameras and the base might also be a factor.
  • 2 Replies
  • 738 Views
