Unfortunatey the threaded hole on the Arlo Pro 2 is only 2 mm from the magnet. Too close to mount on the magnet plus secure the camera with a cable with the loop under a bolt threaded into the hole. The bolt head, even with the bolt cut down to a minimum length interferes with the ball and the ball won't sit entirely in the magnet-socket.
Anyone come up with a solution to secure the camera if it's in an easy to reach location? In the location where I want the camera I want the camera as close to the metal scroll work as possible so don't want to use a swivel ball mount, the shortest of which is 2" projection. The 1/2 ball wall mount is perfect for this application--if I can tie down the camera somehow.
Anyone have success gluing something on the side of the camera to pass a cable? My risk is someone trying to pull it away or slow a thief from taking the expensive camera. Nothing will stop someone determined.
Yeah, it's a compromise. The approach to the front porch and front door is up about 8 steps with the steps leading straight up to the front door with a small landing at the top. A camera beside or above the door generally gets images of the top of people's heads as they walk up while looking downwards at their footing. I get no view of their face. Worse is when they are wearing a hat. Then when they leave I get a view of their backs departing. The metal trellis holds up the roof overhang and there is enough scroll work to make a camera less visible. The best position is on the trellis looking at the door with the camera at head level of someone standing on the landing. But someone walking down the stairs can just reach up and grab it or knock it aside.
This is my latest experiment, mounted in a tree facing the house. I disguised the camera with a black skin with the flexible wire for attaching to branches. I put the camera in a length of drain pipe. There is a second decoy drain pipe elsewhere and lower on the tree. There is a piece of foam inside the pipe so to make it dark inside and you can't see right through the pipe. Other than the foam, the decoy pipe has nothing in it. If someone looks at it they will figure it's a pheremone trap or something to do with the fruit tree. There is black electrical tape to hide the white bezel on the camera. This setup works and I get a view of the front of the house and side gate though the compromise is the tree is a bit far from the house to get a clear view of someone's face when they are at the stairs or at the door. However I get a decent physical description and description of clothing. We get torrential rain so the pipe acts as a shelter and keep rain off the lens.
I've had multiple cameras for over 2 years at face height all on magnetic mounts. The main access for my house is covered by 3 cameras, 2 of which trigger each other as well. I don't think many people have even noticed the cameras let alone tried to steal one. I guess the design is for you to choose either a magnetic mount or a screw mount with the screw mount being the slightly more secure option but being more of a pain to grab the camera down to recharge
I haven't had to change or charge batteries yet. I have a battery charger and with one camear is on AC power so I have a "spare" battery. I figure with a camera on a screw-on mount, I'd push the release button, tip the front of the camera down, change the battery and close the camera again all while leaving the camera screwed onto the base.
Sounds better than my taking each camera down every once in a while and plugging it in for an hour-ish to charge and putting it back up and having to try and make the angulation about the same
