  • 2 Replies
  • 1721 Views
leszekkoc
Hi,
I have setup base station mode as Schedule:
- Armed Mod-Sun 0:00-7:00
- Armed Mon-Sun 20:00-23:59
My station is still Armed after 7:00.
When I edit time range on Schedule (at around 10:00) then at once it switch to Disarmed status.
The system will not arm after this chenage at 20:00.
It is not only the display stays, its the system that capture the movement between 7:00-20:00.
How should I solve this issue?
Reboot the base. Remove your schedule and rebuild it. Check that it's correct by using a web browser (the app sometimes has issues).
leszekkoc
Thank you, that has soleve the issue.
  • 2 Replies
  • 1722 Views
