Running schedules with latest update (Arlo Pro 2)
  • 1 Reply
  • 252 Views
BHudgens
I have had my Arlo Pro 2 for many years and have had zero problems running Arm/Disarm schedules. However, since the latest update and total procedural change, I can't get my automations to run correctly. I set a schedule for 10 pm each day to ARM HOME. I set a second schedule for 6 am each day to DISARM (Standby). The Arm (10 pm) seems to run correctly but the Disarm (6 am) doesn't. I check each morning and it does NOT change the status to STANDBY. I don't think the process is at all user friendly or intuitive. Is there any instructional material that anyone knows of that I can get to figure where I'm going wrong?
Likely your enable lists are set incorrectly.
Can you post screenshots of the two automations?
  • 1 Reply
  • 253 Views
