  • 4 Replies
  • 2795 Views
Solvain
I need my arlo pro 2 cameras to be plugged 24/7 as there is too much activity as to have them running with batteries. What voltage should the charger have? I tried using the charger of my iPhone 8 (with the arlo cable) and it didn’t work... is 5 v ok? Do I need 9? Thanks!
The camera will run on 5v but I don't believe it will charge the battery.
You want to use a Qualcomm compatible (e.g., Quickcharge) dual voltage charger that puts out at least 1.5a @ 5v and 1.1a @ 9v.
Arlo sells both indoor and outdoor chargers for it.
michaelkenward
Sensei Sensei
Sensei
It does here.
Just another user
Believe there was a hw change along the way with the newer Pro2s using 5v in ( due to charging circuit internally )
  as the Pro def needs the dual voltage of 5/9v ( but still should run on 5v )
Solvain
Thanks for the response. I find it odd that with my iphone charger the cameras used to work just fine and I don't know why now they don't. I tried a regular 5v charger (thanks to all of your tips!!) and they work just fine.... it is very odd.
  • 4 Replies
  • 2796 Views
