  • 1 Reply
  • 2550 Views
ElectronicFur
I'm looking into using Arlo Pro 2 for in my garden and home.
Is there a way to stop Arlo triggering due to a robot lawn mower mowing the grass? As robot lawn mowers tend to cut frequently and so run up to 12 hours a day, it would cause a lot of motion triggering in the garden.
Is there a way to set the sensitivity so it will ignore a small robot, but trigger when a person is there?
You'd have to experiment with the sensitivity settings. I'd suspect it should work but only trial and error would give you the answer. The robot and a person would have big IR differences, I would think.
  • 1 Reply
  • 2551 Views
