Reliability - Arlo Pro 2 & Condensation
  • 2 Replies
  • 2706 Views
Paul_Reader
I have just recently install Arlo pro 2 cameras, all going well until the temperature dropped to about 2 degrees C (not cold), all night there is condesation on the cameras and they arenot detecting anything at all, suggestions?
As mentioned, others have used rainx or similar to avoid condensation... I would just try a good cleaning of lens first with a soft cloth.
slompochomp
Luminary
Luminary
You can try something like Rain-X on the lens or repositioning under an eave, etc. I also noticed that when I started using the Outdoor Power Adapter it does not happon as offten any more. This happons on a lot of cameras posisioned externaly. Got to love nature.
If You Got Em....I'll Chew Em!
Netgear & Arlo Beta Tester
  • 2 Replies
  • 2706 Views
